What made the 327 get slow during the gas crisis
Old Sep 26, 2019 | 11:11 PM
Chase Green's Avatar
Default What made the 327 get slow during the gas crisis
I was gifted gifted 1952 dodge truck with a Chevy 327 driveline. I found out it's from a 68 camaro (maybe 69) whatever the slowest year is. The truck has been sitting but started after required maintenance. I'm just wondering what I can put on to get 4-500hp without removing the pistons hopefully.
Any advice appreciated. Thanks all.
Old Sep 27, 2019 | 10:17 PM
oilcanhenry's Avatar
Unless it had had some work done on the valves, modern non-leaded gasoline wont cushion the valve seats on a 68' 327 V8. You may need to use an additive to help with that.
Old Oct 1, 2019 | 11:28 PM
1977-454-Short-Bed's Avatar
I use an additive in my 77' 454 The gasoline today is not the same as it use to be. Adding Octane booster helps a little.
Old Oct 2, 2019 | 3:18 AM
Most states use 10 percent ethanol, so you don't get pure gasoline. Still trying to figure out the OP's post about the 327 cubic inch GM motor. It was discontinued in 1969. before low-compression motors came into being in 1972-1973, with harden valve seats to make up for non-leaded gasoline, and unleaded gas for the catalytic converter.
Johnny Mayday
Camaro
Jun 8, 2017 12:19 AM
mipo7
Camaro
Dec 17, 2016 4:10 PM
T10.5 camaro
Sep 23, 2011 5:25 PM
99kobe
Camaro
Jul 11, 2007 6:30 PM
