What type of flywheel to buy?
Old Aug 24, 2006 | 9:46 PM
mrl's Avatar
mrl
Default What type of flywheel to buy?
Hello,
I need to buy a flywheel for a first gen 350. I visited the Summit website, and I noticed that there are steel and aluminum flywheels, with various weights (15-40 lbs. on average), different diameters and two different tooth count (153 or 168). I have no idea which one to buy. Perhaps someone can give me recommendations if I provide engine specs and application.
Motor:
350 cid .040 over
forged crank and rods
10:1 comp.
750 dp Holley
Wieand team-g intake
iron heads, 2.02/1.60
1.6 rocker arms
comp cam 288 dur. .488" lift
Muncie M21 close ratio 4 speed
Car:
1962 Stratochief (similar to a Bonneville) weighs around 3600 lbs.
gearing is not determined, somewhere around 3.73:1
street tires, normal diameter
This vehicle is primarily for street use.
Does anyone have any suggestions?
Thanks.
Old Aug 31, 2006 | 12:23 PM
uncle bill's Avatar
Default RE: What type of flywheel to buy?
Get a 168 tooth ( Most Common ) 28-35 pound steel flywheel ( McLeod or any good aftermarket brand ) and a matching clutch, pressure plate and throwout bearing. Make sure to use a 350 - 400 Chevy starter and that should match the flywheel. Use a good aftermarket bellhousing to make the package complete and safe.
snowplow
May 2, 2020 6:46 PM
hajboj
May 15, 2008 10:05 PM
sbudac
Mar 20, 2007 4:38 PM
WGVette
Sep 27, 2006 2:48 PM
Zeke
Sep 27, 2006 2:32 PM
