Yet another chevy starting problem
Old Jun 12, 2011 | 3:33 AM
TJLT1's Avatar
Default Yet another chevy starting problem
Thank you for being here. I have a 95 Caprice 5.7 with pol. pkg ran strong and great then sputtered and died. Fuel pump was the culprit (burned in tank) and also changed the filter (frame mount). After repairs, car started and ran for about 30 seconds and died. Car then restarted but would only run (but badly) as long as I held the key in the start pos. Now it's hard to get it to do even that but when it does start the hold key thing is still in effect. With the KO the pump runs and primes like it should. After it dies the pump still runs for a few seconds then stops. I can tell that the car is starting only because of the prime. After dieing, a check of the bleeder valve on the engine reveals that the system is under pressure and full of fuel. I do not have a pressure guage to tell just how much pressure but it is substantial in that it will sqirt about 6ft if I would let it. To me it sounds like an ignition problem. How close am I? This seems to be a common problem with many different solutions. If anyone needs more info please ask. Can anyone help?
Old Jul 12, 2011 | 4:48 PM
Chuzz's Avatar
Sounds to me like you need to replace the ignition switch. I mean the electrical part, not the key and lock cylinder.
Pepper17
Jul 19, 2014 11:20 AM
sypher
Jul 17, 2013 2:34 PM
turboeclips
Feb 13, 2008 4:10 AM
rutler101
Feb 7, 2008 1:46 PM
Greg93
Apr 13, 2007 11:05 AM
