Z-24 coolant system
Old Sep 25, 2009 | 3:49 PM
72gator's Avatar
Default Z-24 coolant system
<!-- / icon and title --><!-- message -->
<!-- BEGIN TEMPLATE: ad_showthread_firstpost_start --><!-- END TEMPLATE: ad_showthread_firstpost_start -->I have an '89 Z-24 with low miles and it runs great. 2.8L engine. However, I am having a problem in that I can't keep coolant in it. At first, I could find no leek whatsoever. Now I see it is leaking out the radiator cap. I switched the cap from the overflow to the radiator, and vice versa, but it still leaks. It is at its worst when I fill the coolant. The thermostat acts crazy once in a while where it will shoot up to 220 or so then just go back down 40 degrees in a few seconds. Any suggestions? Thank in advance. Joe
Old Sep 25, 2009 | 6:25 PM
therewolf's Avatar
Yes, the radiator cap has a small rubber gasket ring which forms a set, dry-rots, and leaks.
Then the pressure in your system drops from @14PSI to 0PSI, and water starts to boil.
Buy a new radiator cap. Get a good name brand like Gates, Dayco, or Stant.
Careful now, it may cost ya 8$ or so...
Old Sep 25, 2009 | 6:55 PM
72gator's Avatar
Well rivereye, I thank you kindly for your advise. If I can buy a descent radiator cap and solve the problem, that sounds great. Once again, I appreciate it.
Old Sep 26, 2009 | 7:08 PM
therewolf's Avatar
And Welcome to the Chevy Forums!
dlaroche
Oct 29, 2014 7:17 PM
DonJuan
Dec 23, 2012 11:28 PM
72gator
Sep 28, 2009 12:12 PM
avidmuskie
Jul 6, 2009 8:05 PM
