HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
06 Chevy HHR LT
Old Sep 20, 2021 | 1:03 PM
bcross82's Avatar
Default 06 Chevy HHR LT
Bcross82 Ok I have been working on my hhr due to a bad mechanic... He installed the wrong sway bar on vehicle and linkage Slt. I also noticed after getting all bolts out except for the rear bracket bolts. That he installed those in upside down. Which has created a huge issue on removing them. I can't fit a 15 mm wrench around the bolt head due to frame and the shaft goes to the top under the metal lip. How he got it on and tight is beyond me.
Could definitely use some ideas
Old Sep 21, 2021 | 7:56 AM
There must be a way if he got them in. Can you get a thin cut off wheel in there to cut the head of the bolt off? Can you post a picture?
Old Sep 21, 2021 | 9:18 AM
post a pic
Old Sep 26, 2021 | 3:03 PM
bcross82's Avatar
Default Sway bar is now ready to remove
What bolts need to be removed on the front cradle to lower it a couple inches. I have 5 bolts out so far but it still didn't lower down
Can someone show me a picture or diagram.
Old Sep 26, 2021 | 5:53 PM
bcross82's Avatar
Default Got it done
Thanks one bolt was stripped
JaredHammel
HHR
Apr 5, 2022 9:48 AM
Yogi
HHR
Dec 30, 2018 9:43 PM
Thumper2004
Nov 30, 2017 2:07 PM
grubbs11
14
Jul 11, 2013 9:23 AM
AndreasChen
Cobalt
Jun 27, 2012 1:16 PM
