HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
Air bag light
Old Mar 24, 2018 | 10:06 AM
Kirkeeair's Avatar
Default Air bag light
Service air bag light is on in my 2012 Silverado ,but there is on check engine light on. I just install a new stereo and I had the battery disconnected for 3 days . How do I fix this.
Old Mar 24, 2018 | 10:25 AM
get the codes read and post them here.
Old Mar 24, 2018 | 10:26 AM
Kirkeeair's Avatar
I for codes it's not throwing any codes just the service airbag lights on
Old Mar 24, 2018 | 10:37 AM
airbag codes are body codes. a scan tool that can access body codes is required...a code reader won't do it. What r u using to check for codes?
Old Mar 24, 2018 | 10:52 AM
Kirkeeair's Avatar
super chip programmer to scan
Old Mar 24, 2018 | 10:56 AM
it can only access powertrain codes
Old Mar 24, 2018 | 11:07 AM
Kirkeeair's Avatar
Default Airbag
One post read , disconnect - and + battery cables and put them together for at least 25 minutes and that would clear it. Sounds shaky ?
Old Mar 24, 2018 | 8:31 PM
Kirkeeair's Avatar
That's it nobody else has anything to say about how to fix this service airbag light
Old Mar 24, 2018 | 9:20 PM
the airbag system does a system heath check and start up and continuously. If the fault is present, the system will detect it at start up and set the light; so disconnecting the battery does nothing becuase even if it did clear the codes (which it doesn't) the system would health check and fail 7 seconds after you key on. If the fault was fixed...at key on the system would heath check and turn off the airbag light.
Old Mar 25, 2018 | 10:00 AM
Kirkeeair's Avatar
Thank you for the response to my question was trying to figure it out without having to take it to the dealer now the question is do I go buy a body scan tool or take it to the dealer?
