HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
blower motor inop.
Old Jan 28, 2010 | 1:44 PM
mferguson's Avatar
Default blower motor inop.
I have no power to the blower motor; blow motor resistor; or blower motor switch. All fuses seem to be good and all power wires seem to have power to the body control module. Does that mean the body control module is bad or possibly needs reprogramed form the dealer. Is their something else im missing. Also i replaced the hvac relay and still nothing. And also the keyless remote will lock and unlock but wont remote start it. it tries but just sounds the horn three or four times and than nothing. so that may be tied into the same problem. Anyone with some suggestions.
Old Jan 28, 2010 | 9:23 PM
shawnvw's Avatar
Banned
check the underhoode fuse panel for a fuse labelled BCM3 in position 4. Its a 40amp fuse. If the fuse is good, pull it out and check for power at the terminals. There should be power there at all times.
Old Jan 29, 2010 | 10:03 AM
mferguson's Avatar
Checked the fuse again and is still good and power going down both legs while fuse is installed. any other suggestions before i send it to the dealership for a new body control module would be great.
mikey379
Jun 28, 2025 11:15 AM
MJPVFL
Jun 22, 2025 1:21 PM
warthogcrewchief
Dec 6, 2013 9:00 PM
Onetimewill
Nov 3, 2007 8:47 PM
AKKen
Feb 16, 2007 10:37 PM
