HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
Engine power reduece on 2007 chevy hhr 2.2
Old Feb 8, 2018 | 12:52 PM
UPTORON's Avatar
Newly Registered
Default Engine power reduece on 2007 chevy hhr 2.2
My 2007 chevy hhr has reduced engine power. Throttle body tps and the accelerator position sensor have been replaced. Throws p0325 knock sensor code. Will bad knock sensor produce the reduced engine power and cause the car to run in limp mode
Old Jun 24, 2021 | 11:41 PM
Felixl's Avatar
Default Chevi v6 2007 1500
I HAVE THE SAME PROBLEM DID YOU FIXED PLEASE ANSWER WHEN YOU HAVE TIME thank you
Old Sep 20, 2021 | 1:11 PM
bcross82's Avatar
Default Reduced engine power
Mine had the same issue and it ended up being the throttle body went bad. You can also check the mass air flow sensor in the throttle body. If it's dirty or fouled up it can have same effect. Broken evap lines can cause this also.
Old Apr 5, 2022 | 9:51 AM
HHR guru's Avatar
change your camshaft sensor. Be careful when you remove it as it has a magnet inside
Old Apr 8, 2022 | 7:37 AM
HHR guru's Avatar
replace your camshaft sensor.
Old Apr 8, 2022 | 7:42 AM
HHR guru's Avatar
camshaft sensor needs to be replaced
Old May 27, 2022 | 2:48 AM
HHR guru's Avatar
Camshaft position sensor needs to be replaced. There are 2 of them, and they are interchangeable.first one is on the far right corner on the head. The second is on the back side
Old May 27, 2022 | 2:49 AM
HHR guru's Avatar
bakeraaron125
Avalanche
Apr 8, 2022 7:39 AM
StephVannah'sMom
Nov 21, 2017 10:25 AM
GRAHAMR
HHR
Dec 10, 2016 10:53 PM
ronguerrero2005
May 20, 2015 4:58 PM
iceman2004
Feb 4, 2015 5:53 AM
