HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
HHR key fob
Old Feb 15, 2009 | 11:41 AM
skywrt5's Avatar
Smile HHR key fob
Hi, does anyone know how to reset a new key fob for a 2006 hhr; we lost one at a church doing and were told that you can reset yourself. Do not really want to pay for advise.
thnx for your help
skywrt5
Old Feb 15, 2009 | 7:13 PM
EvansBlue's Avatar
Keyless Re-program Instructions
Legend:
Insert key and turn ignition switch to "On"
Follow these steps:
-Press Vehicle information button until "PRESS [checkmark] (set/reset)TO RELEARN REMOTE KEY" displays.
-Press Set/Reset button until "REMOTE KEY LEARNING ACTIVE" displays.
-Press and hold both the Lock and Unlock buttons on the keyless remote for approximately 15 seconds. A chime will sound to indicate that the remote is programmed.
-To program additional remotes, repeat step 3. A maximum of 8 remotes can be programmed to this vehicle.
-Exit programming mode by turning key to "Off" position.
-Test Remote(s)
Old May 30, 2013 | 11:43 AM
ramo5150's Avatar
Legend:
Follow these steps:
-Test Remote(s)
Hi Brent,
I have a 2008 HHR and have tried this but can't get to "TO RELEARN REMOTE KEY", How do I get to this point. I have 4 buttons on steering wheel and one says info, is this the "Press Vehicle information button"?
Thanks in advance for this and any other info you can give.
Old Jul 29, 2013 | 7:26 PM
ToooTall1's Avatar
The key fob's have to be setup with a Tech2 service tool which is normally only at the stealer or a shop that has one.
Old Sep 23, 2021 | 7:36 PM
Ripperoni's Avatar
Setup, yes. Would it be possible to re pair one after just replacing the battery, or do I have to take it in for that too
Old Sep 23, 2021 | 8:05 PM
replacing the battery should not cause the fob to lose programming. is the battery clip loose from the board?
Old Sep 23, 2021 | 8:18 PM
Ripperoni's Avatar
I believe so, but I can check. I got the car used, and to my knowledge the battery was dead for a quite a while before I replaced it
Old Apr 7, 2022 | 4:30 AM
HHR guru's Avatar
get a set off Amazon, compatible with your vehicle. Easy to program. Or you can replace with a small screw driver.
2009HHRnut
HHR
Sep 27, 2021 7:07 PM
kcarberry
Jan 24, 2014 5:37 PM
foairish65
HHR
May 1, 2011 7:12 PM
chevykicksbut
Oct 23, 2010 12:32 AM
stanzdz
HHR
Feb 6, 2008 6:46 PM
