02 Impala A/C Problem
On my 02 Impala, when the AC is set to blow from the dash vents only, it actually blows from the dash AND the floor vents. It won't blow from just the dash vents. The floor only setting works correctly.
Any ideas on a cause or a fix would be appreciated. Thanks in advance.
RE: 02 Impala A/C Problem
sometimes when you disconnect the battery- thats when you get these problems come up.
most of the time it blows from the wrong vents...
try turning the **** to the left most position. turn ac off.
disconnect battery for a while. (id try 30-60 min) and then reconnect.
this may force the system to relearn the position of doors that control the air flow.
many times this helps clear up the hiccup.
