2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
02 Impala A/C Problem
Old Jun 23, 2008 | 4:26 PM
slong's Avatar
Default 02 Impala A/C Problem
On my 02 Impala, when the AC is set to blow from the dash vents only, it actually blows from the dash AND the floor vents. It won't blow from just the dash vents. The floor only setting works correctly.
Any ideas on a cause or a fix would be appreciated. Thanks in advance.
Old Jun 23, 2008 | 6:41 PM
HotSauce6226's Avatar
Impala Super Moderator
Default RE: 02 Impala A/C Problem
Try a new HVAC
Old Jun 23, 2008 | 7:09 PM
slong's Avatar
Can you be a litlle more specific? Are you implying that this requires a major repair?
Old Jun 24, 2008 | 1:53 PM
rbarrios's Avatar
sometimes when you disconnect the battery- thats when you get these problems come up.
most of the time it blows from the wrong vents...
try turning the **** to the left most position. turn ac off.
disconnect battery for a while. (id try 30-60 min) and then reconnect.
this may force the system to relearn the position of doors that control the air flow.
many times this helps clear up the hiccup.
Old Jun 24, 2008 | 4:37 PM
i meant buy a new hvac or one from a junk yard and see if it does that same thing. Easy repair
Old Jun 24, 2008 | 4:55 PM
slong's Avatar
Thanks for the suggestions. If the battery thing doesn't work I might try replacing the control unit. Would vacuum hoses have anything to do with this?
Old Jun 25, 2008 | 10:25 AM
Possible
Old Jun 11, 2009 | 10:40 PM
dacrew4009's Avatar
What is a HVAC?
Old Jun 12, 2009 | 5:36 AM
Air conditioning control. 00-03 is vaccum controlled 04-05 is electronic
Old Jun 12, 2009 | 10:24 PM
Gwampa's Avatar
Heating Ventilation and Air Conditioning
user77877
Dec 24, 2006 10:34 PM
user77877
Dec 17, 2006 11:02 AM
