2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
1966 Impala Wiring Problem
Old April 21st, 2012, 7:00 PM
bff198620's Avatar
Default 1966 Impala Wiring Problem
I have a 1966 Impala 327 4 Dr and i noticed on the Compressor that there was a wire that wasn't connected to anything when i bought it (outlined in red). The other wire that is connected to it runs under the Evaporator and into the interior of the car. The A/C does work, but i was just wondering if that cord is essential for a safety feature (like a ground wire). Almost everything is original on the car due to the low mileage, close to 48000 original.
My second question is: I attempted to turn on the lights and they wouldn't turn on in the normal position, only in the bright position will all the lights turn on (except the passenger side turn signal light). I tracked down the wiring for it and didn't find any frayed wiring, only a possible sloppy splice between the wires. When i checked the fuse panel i noticed there was several contacts that were empty and i was wondering if that could be the culprit or not? I did check all the bulbs and they are functional.
Attached Thumbnails 1966 Impala Wiring Problem-compressor.jpg   1966 Impala Wiring Problem-v__3094.jpg
Joseneedshelp (October 4th, 2021)
Old June 10th, 2012, 9:55 AM
hucks 66's Avatar
as for the lights .does the bulb have power going to it, wiggle the plug on the back of the light.
Old June 10th, 2012, 9:36 PM
03SSLE's Avatar
Are you getting power out of the dimmer switch for the low beam circuit?
Old October 4th, 2021, 6:59 PM
Joseneedshelp's Avatar
Default Need help any got a picture of back of fuse box
help me please need picture of back of fuse box
Trackvw
Express & G-Series Vans
October 31st, 2019 7:08 PM
hazard2600
Silverado & Fullsize Pick-ups
February 21st, 2014 7:47 AM
Hokearmy
Sonic (Aveo)
23
July 13th, 2013 11:28 PM
rebelchevy94
March 21st, 2012 10:58 AM
shaft24
March 19th, 2008 4:12 PM
Quick Reply: 1966 Impala Wiring Problem
