1969 impala 396 - champion radiator issue
Recently took on a 1969 Impala project. I replaced the original radiator with a Champion Cooler radiator, which is smaller and more compact (23” wide). The shroud is too big now. Any recommendations on a shroud that will fit an aftermarket radiator? Had anyone run into this problem and what worked for you? *Pictures attached for reference.
Ask Champion Radiator. Why would you install a compact radiator on a big block car? US Radiator sells correct radiators for your vehicle, including ones with greater capacity that will work without modifications.
Slicer280
12
September 5th, 2022 11:12 PM
