2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2000 impala dash/tail lights
Old Oct 21, 2006 | 12:18 AM
ellswore's Avatar
Default 2000 impala dash/tail lights
I have no dash or tail lights. When starting the PRNDL and radio/clock lights up and then goes dim. No tail lights or dash lights. Every once in a while the lights will work correctly. On one other occasion the dash lights flickered and went out again. I pounded on the dash and they came on and flickered at every bump in the road and then just stayed on. Next morning worked fine again. On a different forum another person claimed to have changed both the headlight switch and the BCM and still had no luck. Any suggestions short of a BIC!
Old Oct 22, 2006 | 3:26 PM
313hitman's Avatar
Default RE: 2000 impala dash/tail lights
possible shortage in wiring. hope this example helps but my 92 caprice had no tailights and dim interior lighting. every time I replaced a fuse it blew out in 30 seconds. next morning I followed the wires in the chasis and found both wires melted and shrivled up. have a machanic check the wiring or do it yourself with a wiring diagram. hope that helps...good luck.
Old Nov 5, 2006 | 12:47 AM
modeuce's Avatar
I'm having the exact same problem. Any idea where I could pick up a wiring diagram? ellswore did you get the problem fixed and if so could you share the cause?
Old Nov 5, 2006 | 7:38 PM
golfer's Avatar
ORIGINAL: ellswore
If fuses are blowing then yes the lighting circuit is shorting.
What your describing is an intermittent connection fault. It could very well be a poor ground connection in the lighting circuit.
Did this show "all of a sudden" or after something was added or repairs to the vehicle ??
Old Nov 5, 2006 | 7:39 PM
golfer's Avatar
ORIGINAL: ellswore
Btw... when you "pounded" on the dash and the lights came back on , did this include the tail lights ?
Old Nov 27, 2006 | 2:51 PM
UmbroVR6's Avatar
same thing happened to me.
i was installing my new stereo, and everything was perfect.
but i had some trouble stuffing all the wires back there, so i kept moving things around back there.
all of a sudden i felt a short, and bam lights out.
i took everything out, and tried to find out where that short was coming from....
turns out, nothing i wired was unwired, so i have no clue where the effen short came from.
i checked fuses, everything is fine. any ideas???
Old Nov 27, 2006 | 2:52 PM
UmbroVR6's Avatar
perhaps a wiring diagram? anyone?
TIA!
97 Tahoe "The Rig"
Aug 12, 2014 9:45 PM
flyhound
Feb 1, 2014 11:19 PM
shanoahgood
Mar 20, 2013 10:45 PM
skdevore
Aug 26, 2009 10:18 PM
