2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2000 impala runnin like crap when it warms up
Old May 12, 2009 | 12:58 PM
  #11
OnDaGround's Avatar
Banned
Originally Posted by tedadore
well i forgot but one of my bodies put a scanner on and it said that 6 was misfiring....
Doesn't matter what cylinder was misfirind if you don't know what the code was.
Old May 12, 2009 | 1:19 PM
  #12
HotSauce6226's Avatar
Impala Super Moderator
Originally Posted by OnDaGround
While we are on the topic of plugs and wires, I got a couple questions:
Are the wires in the right firing order?
Are the plugs gapped right?
Did you double check the gapping?
Did you use dielectric grease?
Are the wires laying across each other or all over the place?
Or are they in the holder like they are supposed to be?
Did you double check the part numbers to make sure you got the right ones?
Did you get OEM equivelant or OEM? For example does the car take platinum and you put in coppers or iridium?
Did you clean off the coil and coil towers?
Did you clean off the ICM?
Did you tighten them down snug or use the proper torque spec?
There is nothing wrong with tightening them down snug. You don't need to be 100% exact and you certainly don't want to gorilla them down. But realistically a 1/4 turn can be the difference between a misfire and a normal functioning plug. Normally this is stuff you should know and do as you are doing the plugs so there is no need to come back and check it. You pull the plugs out of the box, make sure they are gapped properly, you put them in. Make sure it's the right wire and it's in the right part of the holder and then you put it on. You clean the coil, coil towers and ICM before installing the wires. When you are done your done. It comes natural to you after you get into the practice of it.
Ill make it easier than this. Did you get ACDelco plugs and wires?
Old May 17, 2009 | 12:41 AM
  #13
pelayo's Avatar
My impala has been doing the same thing. It gave me a random misfire code.
Old May 17, 2009 | 8:41 AM
  #14
Answer some of the questions I asked on this post..maybe I can help
Old Jun 15, 2009 | 3:41 PM
  #15
Rjwood23's Avatar
also you said you replaced all of these things but have you gotten underneath the vehicle after the problem occurs to look at your cat? if when you look at it if its red it stopped up and also when the car is off you can take a malet and tap it if it sounds like rattling then chances are its bad
fetchmesumbacon
Jan 23, 2013 7:33 PM
esotericrite
Oct 15, 2010 10:15 PM
SGTBRYAN.WISE1
Nov 4, 2009 10:13 PM
SGTBRYAN.WISE1
Nov 4, 2009 10:11 PM
WILLI
Nov 30, 2006 12:30 AM
