2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2001 chevy impala ac problems
Old Jul 22, 2011 | 6:44 PM
patient's Avatar
Cool 2001 chevy impala ac problems
Drivers side blows out warm air/passenger side cooler air until all
freon leaks out within a week. Suggestions?
Old Jul 30, 2011 | 8:39 PM
Jfixit's Avatar
Smile A/c problems
If ur freon leaks out in a week thats really a bad leak and no chemical in a can will help that,locate leak by closely lookin at all a/c lines under hood,oil will leak out with freon and appear wet and usually dirt will stick to oil,while rest of lines will look cleaner,this will usually occur at connections or on face of compressor itself. If u continually gas system and dont add oil, compressor will lock up,trashin out ur entire system. If u open up a line to change an o-ring seal do so quickly as freon is heavier than air and generally stay in system in spite of no pressure,however if system is open any length of time,receiver/dryer should b changed also. A/C work can get costly and extensive quickly, u should seek a pro mechanic before any serious problems happen,at least get someone to give u advice that can look at car. In my case, i took apart dash ,after replacin a/c control unit that did not make adif in side to side temps, discovered freon was low in system,after chargin system, temp difference was not as noticeable, probably a design flaw in system. PS dont take apart dash yet nothin wrong with mine as control doors were workin fine. Fix leak and get it vacuumed and properly charged,should do the trick. Good luck Jfixit
WOODSTOCK6978
Dec 18, 2020 2:37 PM
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
Ruby Red
Aug 7, 2010 8:19 PM
sa8901
Jul 15, 2007 10:24 AM
