2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2001 LS Questions...HELP
Old Nov 30, 2007 | 1:37 PM
millertyme771's Avatar
Default 2001 LS Questions...HELP
I have a 2001 LS I did a search on the forum about the tire pressure light and how to reset it through the factory radio but my car no longer has the factory radio so i was wondering what i had to do to reset it and also im having a problem with my driverside heated seat the pass. side works great but my seat doesnt...i checked the fuse and its good so i was wondering if anyone had the same problem and what was there fix thanks for the help
Old Dec 2, 2007 | 1:58 AM
zvm77's Avatar
Default RE: 2001 LS Questions...HELP
put the key in the on position (without starting the car), press the gas peddal down 3 times fast in 5 seconds (or 5 times fast but i think the first way is right) than turn on the car, or put the key back to off and than turn on the car
Old Jun 9, 2009 | 9:53 AM
shaydakiss23's Avatar
Can anyone confirm if this actually works or not? I'm having the same problem. Took my factory radio out and put a Pioneer in and that Low Tire Pressure notification in the message center is driving me nuts!
Since that wont refuses to go away, even though I got an oil change yesterday, the message center refuses to get rid of the Change Engine Oil light as well. I called Chevy about it and left a voicemail a few hours ago, so im waiting to hear back from them. Gonna go to my car during my lunch break and try out this little trick tho. Fingers crossed...
Old Jun 9, 2009 | 10:23 AM
milwaukee_01impala's Avatar
to clear the change engine oil light, turn the key to the on posistion. press the pedal all the way to the floor three time within 5 seconds. it took me 2-3 times to get it to reset the first time i did it.
to get rid of the low tire pressure message, turn the key to the on posistion. pull the headlight switch till the parking lights come on. push it back in and repeat three times. if you push the pedal or pull the switch too fast it wont work right. it might take a few tries to time it right.
Old Jun 9, 2009 | 10:30 AM
So when should I actually be pushing the pedal? I tried the Change Engine Oil trick and it worked! But i'm a little confused on ur explaination for the Tire Pressure Light.
Is the parking light switch the only thing im pushing back in 3 times (is this the actual switch beside my steering wheel)?
Am I supposed to push the pedal at all?
You've been a big help to me, since I joined this forum yesterday. If you wouldnt mind explaining this in a little more detail I'd greatly appreciate it. I know a lot of things...cars just happen to not be one of them. lol.
Old Jun 9, 2009 | 10:48 AM
no problem at all. yes the switch you pull out for the headlights is the only thing you need to do for the tire pressure monitor. just pull it out one click(for the parking lights) push it back in and repeat that three times. its just like resetting the change enginge oil light, but you're using the headlight switch instead of the pedal.
jraquel
May 11, 2012 11:42 PM
riss6270
Jan 30, 2011 12:28 PM
crazymonkey47
Sep 22, 2007 11:23 AM
sw3658
Nov 20, 2006 11:00 PM
dragand
Nov 16, 2006 1:52 AM
