2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2002 Impala Blower Motor Resistor
Old Jun 26, 2010 | 3:27 PM
slong's Avatar
Default 2002 Impala Blower Motor Resistor
I've had to replace my blower motor resistor twice in the last 3 months. Any ideas on what could be causing them to die?? Could it be a voltage issue coming into the resistor?
Old Jun 26, 2010 | 3:35 PM
capucine's Avatar
Are you using the one from GM. It is a much improved version than the original that you had . The new one from GM is sealed in epoxy. I replaced mine on my 2003 impala after I lost 2 of the speeds. What a job to replace! I took the front seat out so I coud have a bit more place to work. I can tell you that I was talking to myself alone on this terrible tight job.
Old Jun 26, 2010 | 3:44 PM
slong's Avatar
I replaced the original part with an aftermarket unit and then replaced that one with the same aftermarket. I just noticed that one of the pins in the wiring harness is slightly melted and blackened.
ke4wpv
Uplander
Oct 6, 2011 8:14 PM
holyspatulaboy
Apr 22, 2009 5:32 PM
capnhooks@yahoo.com
Jan 13, 2009 6:02 PM
aeroclimb
Dec 3, 2006 9:22 PM
Bobsyouruncle
Oct 31, 2006 12:11 AM
