2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2003 impala loss of power
Old Jun 28, 2009 | 1:23 PM
chriswilliam1's Avatar
Unhappy 2003 impala loss of power
Apppreciate any help
My impala has lost power on climbing hills and any rpm over 4000. When in park reving it up to 4000 it starts surging.
I have replaced the fuel filter and checked pressure while running and when engine is off and checks out ok.
I have removed the exhaust pipe at the manifold to check back pressure and ran the engine. but still have problem.
I have no DTCs
Engine idles and runs fine below 30 mph unless under a heavy load like a hill.
3.8 L engine with 100100 miles. I have taken the plugs out and they look fine but will be replacing anyway since the book suggests it.
I forced a DTC by putting in 1st gear and with wide open throttle the engine started missing around 4000 rpm. DTC code was Random misfire. PO300.
any thoughts?
Old Jun 28, 2009 | 2:36 PM
HotSauce6226's Avatar
Impala Super Moderator
Clogged Cat
Old Jun 28, 2009 | 2:50 PM
I had the exhaust system disconnected and still had the problem. Any other thoughts?
Old Jun 29, 2009 | 5:33 AM
Id do plugs and wires first
Old Jul 5, 2009 | 7:28 AM
milwaukee_01impala's Avatar
when in park it will only rev to about 4k rpms, there is an electronic rev limiter on it so you wont damage any internal parts by over reving, so it will surge like that in park.
how did you get the exhaust off at the manifolds? the bolts on the flange at the top of the downpipe are a bitch to get off. ???
Old Feb 14, 2012 | 4:21 PM
My problem was a plugged Cat. I found just unloosening the bolts at the manifold did not work. I had to slide the pipe off the studs. once I did that the engine ran fine under load.
My symtom was not a misfire but a lack of power over 40 mph
hope this helps.
mnkstock01
Nov 3, 2025 8:19 AM
Fishnbum1001
Dec 11, 2021 11:00 AM
Hundt
Sep 14, 2012 12:07 AM
DavidS
Apr 9, 2010 8:08 AM
saqibwaraich
Dec 25, 2008 7:54 PM
