2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2004 impala front signals work back dont
Old Feb 8, 2015 | 10:40 PM
ky1duck's Avatar
Default 2004 impala front signals work back dont
It started about a month ago the left rear turn signal stopped working follow by the right rear one. Both front work just fine. Also the brake lights stopped working to except the middle one. After all the reading I have done am I right in assuming that the turn signal switch in the column is bad and needs to be replaced.
Thanks
Old Feb 8, 2015 | 11:48 PM
sledge.impy's Avatar
Thanks
You didn't say - but
1) Have you changed the bulbs?
2) Are the bulbs in the socket loose and work when you push them in? Then the sockets are bad.
Also I don't know what you've been reading.
Old Feb 9, 2015 | 5:49 AM
a55bruce's Avatar
Do the lights work with the hazard flasher button? That will tell you if the wiring/bulbs/sockets/grounds are OK or not. Also, the hazard switch may be the problem, try cycling it on/off a few time.
Old Feb 9, 2015 | 5:57 AM
ky1duck's Avatar
Sorry about that yes both bulbs have been changed. Also the Hazzard do the same thing work in the front but not in the back. Running lights also work fine front and rear. Also checked ground and it is ok
Old Feb 9, 2015 | 7:08 AM
a55bruce's Avatar
Sorry about that yes both bulbs have been changed. Also the Hazard do the same thing work in the front but not in the back. Running lights also work fine front and rear. Also checked ground and it is ok
I think this rules out the turn signal switch. For a double check see if there are yellow and dark green wires (should match the colors at the bulbs) coming out of the steering column. Check these with a voltmeter or test light.
If you have good voltages there I'd start w/ checking the wiring of the lights, sockets, and harness connectors. Use a voltmeter or test light to find where you are losing the connection.
Old Feb 9, 2015 | 7:58 AM
ky1duck's Avatar
But I am also right in that the brake lights also run through the turn signal switch to. Also the center break light still works.
The hazard switch wouldn't affect the brake lights
Old Feb 9, 2015 | 8:34 AM
a55bruce's Avatar
On this car aren't the rear turn signal and brake lights the same? Or are they separate bulbs. If they are the same, then the hazard switch and turn switch both control the lights.
219Impala
Jul 3, 2012 8:17 PM
uncledave11
Sep 10, 2010 7:12 AM
dracx619
Dec 26, 2007 8:42 PM
toicy4ya
Sep 5, 2007 11:12 AM
eventemplawrence
Mar 10, 2007 5:30 AM
