2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2005 impala
Old Nov 10, 2019 | 1:28 AM
Andy Carter3's Avatar
Default 2005 impala
I have a 05 impala 3.4 and the cluster seems to flicker sometimes the light stays on when driving but the message light and the gear and mileage light flicker on and off sometimes it works completely fine and sometimes it doesn’t, I checked the fuses and they seem fine. Is there a loose ground wire somewhere perhaps? Or is my cluster faulty? Help please thanks
Old Nov 10, 2019 | 1:33 AM
oilcanhenry's Avatar
Likely could be either one. Might be a corrosion issue as well. Tighten down all the grounds and check you fuse box too.
Old Nov 10, 2019 | 3:16 PM
Frank3's Avatar
I've had a bad dimmer control for the instrument panel cause this as well.
Old Nov 11, 2019 | 9:50 AM
there is a thread on this site where someone replaced a mosfet transistor in the cluster to fix the odometer, gear indicator and message bank lighting. It may also be a bad solder connection in the cluster.
WilRace
Jun 29, 2018 4:42 PM
person222
Apr 22, 2016 12:10 AM
den052
Aug 2, 2015 6:51 PM
juanb87
Sep 6, 2010 6:05 PM
newbie321
Jun 26, 2009 5:30 AM
