2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2006 Impala Rear defog problem
Old Feb 9, 2009 | 11:28 PM
06impalaltz's Avatar
Default 2006 Impala Rear defog problem
I have a 06 impala ltz my rear defog doesnt work, the indicator light lights up but no action!!.... I cant find a defog relay anywhere, I thought that may be the problem but nobody has the part?? Any help would be great .... I checked all the wiring and its connected in the back window??
Old Feb 10, 2009 | 12:36 PM
HotSauce6226's Avatar
Impala Super Moderator
Can we move this into Impala Section
Old Feb 10, 2009 | 3:19 PM
shawnvw's Avatar
Banned
Relay is under the hood in the fuse box at the right strut tower. Also check the 40amp fuse labelled BATT3. It should have power when the defogger is turned on. If it does have power, then the relay is good. If it doesn't have power the problem is between the fuse and the control head.
If you do have power at the fuse, check for power at the rear window on the purple wire. If you have power there, then the problem is most likely on the other side of the window in the ground circuit. If you don't have power, then there is a broken wire between the window and the fuse
Mason155
Sep 7, 2013 10:33 AM
bruce.t.mann
Aug 20, 2012 6:18 PM
itsmacintosh
Nov 9, 2009 8:39 AM
