2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2011 engine problem
Old Jun 12, 2012 | 9:57 PM
Chrisb_75's Avatar
Default 2011 engine problem
Every once and a while the heat gauge will cut out and the warning light will say engine over heating A/C disabled and the fans will kick in on high.. Well the engine is NOT over heating and if I disconnect the batt and reconnect it everything is fine for a couple days.. Now I have a 2 part question #1 what can be causing this and #2 the chime gos off for 10minutes when it happens and is there any waY I can dissable the chime in the dash? Yes it's a 2011 and it's warranty has run out so there's no way I'm going to the dealer, thanks
Old Jun 13, 2012 | 6:25 AM
Bad temp sensor or short in the wiring are 2 possibilities.
Old Jun 13, 2012 | 7:52 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Chrisb_75,
I agree with "oldchevy", it sounds like there may be an electrical issue, just a suggestion, not a diagnosis. I recommend having the vehicle inspected for a more accurate diagnosis.
Louis
GM Customer Service
Old Jun 13, 2012 | 11:01 AM
Chrisb_75's Avatar
Well it's not the temp sensor.. I tried that. It does other crap too (traction controll) and I'm almost willing to bet its the ecu
Old Jun 24, 2012 | 8:47 AM
klutz1's Avatar
To start check all ground wires including the batt. Clean the batt terminals. You state that if you reconnect the batt. it is OK for a few days.
70cst
Mar 1, 2015 3:18 PM
linux2
Jun 24, 2014 7:59 AM
bzb1sk
Oct 18, 2012 7:05 PM
GreaseMonkey4x4
Jun 25, 2012 10:01 AM
janno
Jun 15, 2011 2:14 PM
