2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2014 impala lt1 quieter than lt2 6 cyl
Old Feb 5, 2015 | 10:28 AM
bumperking's Avatar
Smile 2014 impala lt1 quieter than lt2 6 cyl
the 2.5 is so much quieter and rated a better motor than 6 cyl why?
Old Feb 5, 2015 | 10:47 AM
Impala-Blue-2.'s Avatar
The 2.5 Impala uses active noise canceling to make the car quieter because of the louder nature of the 4cyl than the V6. as for the 2.5 being rated a better motor then the V6, where did you read this ?
Old Feb 5, 2015 | 12:20 PM
sledge.impy's Avatar
I found this review for you: 2014 Chevrolet Impala 2.5 1LT First Drive - Automobile Magazine
Also these videos here explain some more stuff:
Chevrolet Video Portal - 2014 Chevrolet Impala is Quietest Ever
Old Feb 5, 2015 | 1:09 PM
bumperking's Avatar
Smile
Originally Posted by Impala-Blue-2.
The 2.5 Impala uses active noise canceling to make the car quieter of the louder nature of the 4cyl than the V6. as for the 2.5 being rated a better motor then the V6, where did you read this ?
the engineering in this double overhead cam motor is so advanced it almost develops the same hp in the old v6 impala used.they are selling my than the 6cyl people that drive both opt for this marvel of a engine. It has really surprised GM. ONLY34%BUYING THE NOISEE 6 CYL
Old Feb 5, 2015 | 2:12 PM
The 6 cylinder is not noisy.
Like I mentioned before - the car does not struggle with a lot of extra weight and passengers and handles mountains with ease.
The engineering is the 6 cylinder dohc is also advanced.
Old Feb 5, 2015 | 2:40 PM
bumperking's Avatar
Smile
Its not noisy unless you compare it to the 2.5 marvel
Old Feb 5, 2015 | 2:46 PM
bumperking's Avatar
Smile The 2.5 engine does not struggle ever
Go drive it. Im not knocking the 6 cyl its just that the 2.5 is so quite and the power is adequate.
Old Feb 5, 2015 | 3:02 PM
Not everybody wants "Adequate" Some of us like "Stellar", "Outstanding", and just plain FUN !!!
The 2.5 is actually not nearly as quiet as the 3.6L V6, that's why GM had to add Electronic Active Noise Cancellation to the audio system to keep the noise level down.
If you pull the fuse for the Audio system, and drive it, you will see the actual noise it creates.
Old Feb 5, 2015 | 3:27 PM
I don't need to go drive it. I already have a 2014 2ltz.
I just came with a 2.4L DOHC j-body (2002), which was pretty adequate for a small car.
chrisk
Jul 6, 2016 7:14 PM
chunt5
Jul 23, 2014 12:18 PM
Gwampa
Apr 1, 2009 9:27 PM
