2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
61 Implala upper steering coupling
Old Sep 4, 2011 | 3:43 PM
DHT112A's Avatar
Question 61 Implala upper steering coupling
Inside the coupling under the bearings the manual says there are a couple of "wave washers" to tension the bearings. I don't remember removing any wave washers and there really isn't clearance for them. I don't see any wear pattern where there were any in there. Does anyone know if these were on every model?
Old Sep 4, 2011 | 4:42 PM
kevinkpk's Avatar
These are more like a "plate" as big as the coupling, not like what you'd think a washer would be underneath a screw. Those things are an adaptor to the steering rod.
Old Sep 4, 2011 | 9:20 PM
DHT112A's Avatar
I am not sure what you mean. If you are referring to the nickel sized plug in the bottom of the bell shaped housing, that is not what I asked. The steering shaft has two ***** at the lower end that go into a bell shaped housing. There are two square bearings that sit on the *****. These bearings slip into grooves in the bell shaped housing. Under these bearings are shown to be little washers approximately 1/4" in diameter. These push the bearings out as a thrust bearing would push on whatever it is supposed to load. Did all of these come with those little wavy washers?
jasonthatsme
Apr 6, 2015 9:36 PM
thegibl
Apr 7, 2011 12:18 PM
hesreallygood
Nov 7, 2007 6:25 PM
slinky
May 18, 2007 3:20 PM
slinky
May 16, 2007 9:57 PM
