2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Atf
Old Jan 8, 2012 | 5:44 PM
kzov21's Avatar
Default Atf
Lately my transmission has been missing gears. I would accelerate and it wouldn't shift and my rpms would go through the roof.
Im right at a 30,000 mile interval from when I originally bought the car and thought about getting the fluids flushed but it occurred to me that I have no idea if its ever been changed or not.
Question is.. Without knowing the previous maintenance should I risk changing the fluid at 158xxx miles?
Old Jan 8, 2012 | 7:29 PM
HotSauce6226's Avatar
Impala Super Moderator
Trans flush at 158 is not the best idea.
ALso If you change the trans fluid, try dextron 6
Old Jan 8, 2012 | 8:18 PM
check the fluid level and condition first. Does it smell burnt or is it brown in colour?
What gear is it stuck in? Will it upshift when in the manual gear shift position...m2, m3?
Any dtc present? Throttle position and Vehicle speed are the 2 biggest inputs for shift timing...does the speedo work?
60 000miles is the service interval for trans fluid service...hopefully you don't have crud in the valve body causing a stuck shift valve.
EAndres1486
Mar 4, 2012 11:43 AM
Duenas&BigBertha
Jan 21, 2012 12:29 PM
cs361
Jul 17, 2011 4:02 PM
Rez
Feb 20, 2010 2:56 PM
ncseahawk
Feb 15, 2010 11:18 AM
