2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Blend door actuator disconnect 2008 Impala
Old Oct 29, 2024 | 8:20 AM
michael77's Avatar
Default Blend Door/Heat Actuator Disconnect 2008 Impala
Can I disconnect the power to my actuators which are both clicking for a temporary fix?.... One is located on the left side of the glove box (used as heat/cold control for passenger side) and one is located on the right side of the glove box (used as outside/inside air circulation flow).... Presently it is Oct. so I would set the heat/cold control to hot and the air flow control to floor/defrost setting..... Also, I would set the outside/inside air circulation control to outside air flow. ....Next, I plan to disconnect the power to both actuators hoping the actuator settings and heat would stay as they were before disconnecting the power. ....Has anyone tried this as a temporary fix while I wait to receive the replacement actuators?.... Are these two actuators the same or different?.... Any advise/suggestions would be appreciated. Thanks
Jfeen
Feb 10, 2024 8:41 PM
stayathomedad
Oct 30, 2023 10:59 AM
shamrockcustoms
Jul 15, 2014 7:56 PM
Stephen Doak
Feb 2, 2013 6:48 PM
