2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Dealership Says They Can’t Fix the Recall
Old Jul 12, 2021 | 1:57 PM
Caleb02's Avatar
Default Dealership Says They Can’t Fix the Recall
I have a 2003 Chevy Impala with the recalled ignition switch. When I took it to the Chevrolet dealership to get the recall fixed, they tried for a while and then told me they couldn’t do it because I had an aftermarket key. The key I have requires a lot of jiggling to get it to turn and can be removed while the car is running. Is there really no way for them to replace the ignition switch?
Old Jul 12, 2021 | 4:41 PM
Rednucleus's Avatar
I assume it's not an aftermarket ignition?? Seems they should replace the switch, keyed to your original locks and get you new keys as well.
Old Jul 12, 2021 | 6:34 PM
hanky's Avatar
I would ask for a better explanation of why they can't destroy the old one and install the modified one, sounds a little fishey to me.
Try another dealership.
Old Jul 12, 2021 | 9:03 PM
ignition switch recall 14123 requires gm to inspect the ignition switch and check the part # on the switch. Gm has identified bad ignition switches they have made. This recall would not apply if an aftermarket switch installed. What key you have is irrelevant.
if you are saying the switch can't be checked as the key can't be turned to remove it.....have a new key cut from a code and try it. DO NOT TRACE THE OLD KEY or you will have the same problem.
Old Jul 13, 2021 | 6:59 PM
Caleb02's Avatar
I have an aftermarket key and the original ignition switch. The key can be turned if it is wiggled a lot and then the car starts just fine. The dealership said they couldn’t do it because of the aftermarket key.
Old Jul 13, 2021 | 7:03 PM
Caleb02's Avatar
I will go to another dealership and if they tell me they can’t do it I will ask for more details.
Old Jul 13, 2021 | 10:56 PM
how was the aftermarket key cut...traced or cut from a code. If you traced it...its junk....try a new key cut from a code.
Old Jul 15, 2021 | 7:48 PM
Caleb02's Avatar
I don’t know. I just got the car a few months ago and I didn’t ask the previous owner. The key does look fairly worn though.
jla74
Dec 15, 2020 3:41 PM
Toyhhr06
HHR
Mar 9, 2020 12:52 PM
Eagles
Nov 20, 2014 4:05 PM
Trentjh
May 17, 2014 8:41 PM
