2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Engine troubles 350
Old May 14, 2019 | 4:09 PM
  #11
kevinkpk's Avatar
R is the HEI resistor, the coil has full battery voltage during crank.
Old May 14, 2019 | 4:10 PM
  #12
kevinkpk's Avatar
When the ignition switch is on, and not crank, the resistor side power is to the hei.
Old May 14, 2019 | 4:28 PM
  #13
kevinkpk's Avatar
Looks as if the battery to solenoid, yes. ignition switch to coil, distributor yes, but only if the ignition switch is engaged, and I have to make an assumption you are only getting power to the coil with the ignition switch while cranking. On the ignition switch, you have to have a power wire to the distributor with the key switch on, not only while cranking, but hot when the ignition switch is on.
Old May 14, 2019 | 11:53 PM
  #14
Caprice65's Avatar
Theese are my terminals, only got three. Where do I put the ignition wire? I think its the orange one.
Old May 15, 2019 | 12:11 AM
  #15
Irish_alley's Avatar
I'm here for the party
man thats an odd looking starter solenoid
Old May 15, 2019 | 1:32 AM
  #16
Caprice65's Avatar
Think I’ll just remove the wire from the starter and just use the one from the key switch
Old May 16, 2019 | 2:08 PM
  #17
i never seen that type of starter, can you put on a starter with the "S" and "R/I" terminals?
Old May 16, 2019 | 2:19 PM
  #18
Caprice65's Avatar
Its a ministarter
Old May 22, 2019 | 7:10 PM
  #19
oh makes sense as to why ive never seen one lol
