Last edit by: IB Advertising
Browse all: Engine and Powertrian
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Alternaor
Finally a cheap passlock fix!
#162
Can you email me how to remove the ignition switch and clean the contacts on 2000 chevy k1500 mpthomas00@gmail.com
johndoe28, Would you send me the detailed instructions on removing the ignition switch and cleaning the contacts on the 2002 Impala? My email is dkfm@hotmail.com
#163
Visiting my son-in-law in MI and he had this same problem. First he took it to a repair shop who "said" he put in a new ignition switch?? and charged $500!! Worked for a short time. Then when it recurred he bought a Newrockies. Didn't work so he returned it. Then I arrived and did the "re-learn" process several times which seemed to be taking, for a few hours!!! (next morning it wouldn't start again) So, I went to Radio Shack and spent ~ $4 for the 2200 ohm resistor pack and a European Style connector block for the by-pass trick. Again, seemed to work for only a few hours after re-learn. Then I found this post and the "2001 Malibu no start" post and suspected the (new) ignition switch. So, I removed the black plastic cover over the contacts and voila, blackish contacts. Cleaned them with a screwdriver (ok, but even a q-tip or pencil eraser might have worked - I was too lazy to go get either). A few strokes and they were shiny. Car started perfectly every time since. Another post though said he had to it again in a year or so. Thanks EINst & jondoe28!!
#165
I have a slightly different problem, My S-10 2.2L flex fuel 2wd. will start and run about 5 seconds and turn off and then the security light starts flashing a code three regular flashes followed by two quick flashes or visa versa there is no two second wait before or after the flashes so what I am asking does anybody know the codes for the security system?
#167
I am hoping to get a copy of the wiring diagram so i can finally bypass the passlock. I would really appreciate it. orlando.marquez@live.com
#168
Here's the wiring for the KEY fix: GM Passlock Security Fix
But I did it and it still did not work BECAUSE THE IGNITION SWITCH WAS BAD (resistance at burnt contacts). I got one for around $40.
#169
Hello All,
Ok I was able to Bi-pass my pass lock in my 2000 Impala. I put my factory radio back in and guess what? Yep went right back into security mode. it is starting to really irk me off. Now a little about the bi-pass that I did to the car. what i did was take off the front face of the dash then with a 1/2 watt 2200 ohm resistor and a terminal block, I pulled the ignition cylinder out then cut the yellow and black wire's ( the small ones not the big fat ones) Then I put the wires into the terminal block with the resistor ( used the wires going towards the BCM not the cylinder lock ) then did the 15 min re-learn from off to start. waiting a few hours due to other obligations got home and the car fired right up. yesterday decided to put the dash back together was jamming out with the radio on happy as a bug in a rug went to start the car back up and it is back in security mode- now im going to do the 30 min relearn on the car again today and see what happens- I will post what happens latter- Now the Bi-pass that I used was recommended by a Retired GM Engineer of 30+ years- But I am wondering if the damn radio has something to do with it as it is- please help me out with this issue. Thanks
#170
OK if you have the pass lock 2 system in your GM do this trick if you want to Bi-pass the the ignition cylinder system- get the key cylinder out leaving the wires hooked up you have to cut the little thin black and yellow wires hook them up to a terminal block with a 1/2 watt 2200 ohm resistor- do the relearn on the system and it should work.
