2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Fuel Pressure Test on Flex Fuel Engine
Old Dec 11, 2014 | 7:40 PM
  #11
jager2's Avatar
Hello
Old Dec 11, 2014 | 9:50 PM
  #12
Originally Posted by jager2
Hello
Welcome to the forum...
Give us some detail on what you are working on, year and engine size...
Do you have any codes or check engine lights on...
What work have you done so far to address the issue
Old Dec 14, 2014 | 8:43 PM
  #13
Frank3's Avatar
What about fuel pressure or the fuel pressure regulator?
Old Mar 6, 2021 | 12:58 PM
  #14
Mister Criminal's Avatar
Default 99 Tahoe crank no start/no fuel pressure
Ok, so I have this problem with my 99 Tahoe that I just bought, but let me give you a little history on it first. The guy that I got it from said it had been sitting in storage for the past three years and during that time someone broke into it and tore up the dash. He told me that it ran but a week prior sputtered and would not start, said it was fuel pump or relay. Being the all trusting sucker that I am, I took his word for it and bought the Tahoe. That s when my nightmare began but I refuse to give up.
Since it was broken into, the ignition was drilled and a resistor was connected to the orange/black wire to the yellow wire on the key lock housing. Not knowing its purpose, I removed it and replaced the key lock cylinder. I also replaced the fuel pump (cleaned and flushed tank), the fuel filter, fuel relay, and intake air filter. After all this and a new battery the truck will turn on then die. Tried relearn procedure and every pass lock bypass I could find and I still cant get it to stay running. Another thing is after hooking a fuel pressure tester up to it, its not registering any pressure from the key turned to on all the way to cranking engine no pressure registers. If anyone can give me any advice or point me in the right direction I would really appreciate it. Ive made it my mission to get this truck running because everyone said i cant
Thank you for your times and any advice
Old Apr 2, 2021 | 5:51 PM
  #15
Wolfe7783's Avatar
try using a jumper wire from positive battery post to the fuse box, next to the fuel pump relay is a prime terminal. This will turn on the fuel pump.
David3954
Jan 21, 2023 5:55 PM
Matt Rao
Jul 29, 2016 4:21 AM
3800Impala
Oct 16, 2015 7:04 PM
Wexe49
Dec 30, 2014 1:15 PM
bigjesstd
Apr 4, 2007 12:06 AM
