2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Hose ID please
Old Oct 27, 2016 | 1:57 PM
crawdad's Avatar
Default Hose ID please
It's the hard hose coming out of the intake going to the rear of the intake manifold, right under the ignition control module, which actually prevents it from being removed. It seems to be a very loose fit there. If I can't correct the fit somehow I'll need to order one if it's leaking. I have a 2003 Impala 3.4L Base that has a -15 LTFT at idle which disappears at higher rpm. By the way, the pic is not my actual car. Thank you.
Old Oct 27, 2016 | 2:47 PM
kevinkpk's Avatar
It's an air line to the backside valve cover. I have the same on my 3.1. You can get it off without pulling the module. I used a small prybar under the elbow on top of the valve cover, gently pry it off.
Old Oct 27, 2016 | 2:50 PM
kevinkpk's Avatar
GM 24504646 PCV Tube, here's the gm number
Old Oct 27, 2016 | 4:39 PM
crawdad's Avatar
That's great, thank you.
Old Oct 27, 2016 | 7:50 PM
crawdad's Avatar
Default Hose won't fit?
Odd that parts sites either don't have it or say it's not for my car, only up to 2001 and no Impalas are listed. And I can't find the part that is for my car. It certainly looks the same. I wonder if someone would take a look at these two photos and tell me if you think it would fit? As best as I could measure, it's about 17" long. Thanks.
Old Oct 27, 2016 | 10:15 PM
crawdad's Avatar
Default Update
After navigating some of the GM parts sites, pretty sure my part is 12581196 although why they call it a harness is confusing.
Old Oct 28, 2016 | 8:35 AM
kevinkpk's Avatar
There is another one that won't fit the parts house (autozone) carries. I replaced mine about 3 months ago with the part number I posted. Mine is a 96 model 3.1, but should be the same.
Old Oct 28, 2016 | 8:40 AM
kevinkpk's Avatar
Is this it?
Old Oct 28, 2016 | 9:57 AM
crawdad's Avatar
It looks similar but I've found several that are similar but fitment is for other models. If I do purchase one, I'll go with the 12581196 since at least one of the large gm parts suppliers online confirms that it fits the 2003 and has a fairly good image of the part whereas most of them don't even have an image.
