2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Just a question
Old Sep 12, 2012 | 8:29 AM
kimmi73's Avatar
Default Just a question
We have a 2008 Impala our door chime is all of a sudden got quiet and the low fuel chime too. could this be the relay fuse under the hood in that box. thanks
Old Sep 13, 2012 | 6:38 AM
junkman104's Avatar
Check the drivers door speaker, my truck did the same thing.
Old Sep 13, 2012 | 2:43 PM
Nicky Nine-Piece Massino's Avatar
Junkman's right. The chimes sound thru your drivers side speaker. If it blown or on the way, that could be the problem. Turn the radio on and fade all sound completely to the front and to the left. If there's a lot of popping and buzzing, you need new speakers. Sonicelectronix.com or crutch field.com are two great options for finding replacements. If the sound is fine, look to the group of buttons to the right of the gauge cluster. Cycle thru the second one from the bottom (the one with a list and a check mark) until you see ur gauge readout say "door chime volume" or something along those lines. Make sure it's up loud enough for you to hear comfortably. Then hit the bottom button (the big check mark) to confirm your choice. If that doesn't do it, maybe a loose connection behind the head unit? Good luck!
Old Sep 13, 2012 | 5:48 PM
kimmi73's Avatar
ok thank you will check the speakers.
scycleguy
Apr 8, 2008 10:21 AM
BlackDenali
Sep 18, 2007 2:36 PM
cutiger95
Mar 6, 2007 1:57 PM
1hot650r
Dec 17, 2006 5:17 PM
