Keep blowing out water pump gaskets
I replaced my water pump and it lasted one week until the gasket blew out. So I got a better gasket and that one lasted three days before it blew out. Why do these gaskets keep blowing out even though I used sealer. I noticed the top radiator hose doesn’t warm up as fast as the bottom one. Is the radiator clogged up putting pressure on that gasket seal?
Here is a youtube vid.Frankly I would NEVER use that much sealant on the gasket,but other then that, seems legit. Torque it down slowly and alternating bolts.
Check your REAL coolant temp hot. Also, slapping sealant on the gasket is not recommended. perhaps enough to keep it in place, but no more then that. Are you torquing the bolts in a rotating fashion, down to specs?
https://www.youtube.com/watch?v=T8XscndbK18
TH3A5SA5S1N4204
January 17th, 2010 6:47 PM
SuperTexan
October 29th, 2008 4:10 PM
