2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
New Guy with a few questions.
Old Jun 23, 2008 | 10:24 AM
phillyimpala's Avatar
Default New Guy with a few questions.
Hello everybody. Well I recently purchased a O2 impala with 109,XXX on it and I have a few questions. First my fuel guage is eratic and isn't accurate, what's the fix to this? Also I was told by my mechanic that the belt was worn so I went ahead and replaced that and now a week later the new belt looks as though it is fraying along the edges as well so I'm guessing something is eating the belts? Another problem I occasionally have is that when the car is at cruising speeds there is jerking every once and awhile but it only last for 2 seconds and I don't think its a misfire because the CEL isn't on.
Old Jun 23, 2008 | 1:10 PM
rbarrios's Avatar
Default RE: New Guy with a few questions.
eratic fuel gauge- may be caused by sulfur buildup on the fuel level sending unit-
a POSSIBLE fix, is to run a bottle of TECHRON.
Maybe 2.... see if that helps.if it doesnt then replacement....
the belt- look for loose or wobbly parts.
the last time I hadmy belt wear from the sides- the water pumpsshaft was failing- allowing wobble on the fan clutch.
this wasenough to make the belt rub on other pulleys......
Old Jun 23, 2008 | 6:40 PM
HotSauce6226's Avatar
Impala Super Moderator
Also have your CELs checked
Old Jun 25, 2008 | 10:09 PM
Well I tried the techron and ran maybe 15 miles on it and haven't noticed any difference so far. To explain the fuel gauge problem a little more it's basically when I first turn the car on it seems like it's the accurate reading but as soon as I start driving it goes straight to a full tank and stays that way until I shut the car off. Also as I watch the belt as the car is running it appears that the tensioner is wobbly and that is still covered under warranty so I'm gonna look into getting that replaced.
dnovack
Jan 24, 2013 9:19 PM
07hoe
Feb 16, 2011 8:58 PM
Spice Boy
Jan 27, 2010 6:37 AM
clayton2127
Aug 14, 2007 9:17 PM
83 Chevy
Jul 19, 2007 6:42 PM
