2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Old Jul 24, 2015, 4:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
Oxygen sensors
Old Jun 15, 2009 | 10:07 PM
firepop5's Avatar
Default Oxygen sensors
On a 2001 Impala with 3.4L, how many oxygen sensors are there and where are they located?
Old Jun 16, 2009 | 12:32 AM
Mike Sigmond's Avatar
ROTM Coordinator
You have 2.
One before the cat & one after the cat on your exaust pipes.
I cant find a picture but here is what the book says...
Removal & Installation
Upstream HO<SUB>2</SUB> S1
To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the HO<SUB>2</SUB> S1 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust manifold.
  1. If necessary remove the fuel injector cover.
  2. Disconnect the HO<SUB>2</SUB> S1 sensor electrical connector.
  3. Using an oxygen sensor removal tool carefully remove the heated oxygen sensor.
To Install:
  1. Coat the threads of the oxygen sensor with anti-seize compound
  2. Install the HO<SUB>2 </SUB>S1 sensor. Tighten the HO<SUB>2</SUB> S1 sensor to 30 ft lb (41 Nm).
  3. Connect the HO<SUB>2</SUB> S1 sensor connector.
  4. If removed, install the fuel injector cover.
Downstream HO<SUB>2</SUB> S2
To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the H0<SUB>2</SUB> S2 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust pipe.
  1. Raise and safely support the vehicle.
  2. Disconnect the HO<SUB>2</SUB> S2 electrical connector.
  3. Using an oxygen sensor tool carefully remove the H<SUB>2</SUB>0 S2.
To Install:
  1. Coat the threads of the HO<SUB>2</SUB> S2 with anti-seize compound.
  2. Using an oxygen sensor tool install the HO<SUB>2</SUB> S2.
  3. Tighten the sensor to 30 ft lb (41 Nm).
  4. Connect the HO<SUB>2</SUB> S2 sensor electrical connector.
  5. Lower the vehicle.
Old Jun 16, 2009 | 4:41 PM
firepop5's Avatar
Thanks alot!
Old Jun 16, 2009 | 6:45 PM
ROTM Coordinator
Originally Posted by firepop5
Thanks alot!
you bet.
Old Jun 16, 2009 | 9:04 PM
milwaukee_01impala's Avatar
the upstream o2 sensor is on the rear exhaust manifold.
may i ask what you're inquiring about these for?
Old Jun 17, 2009 | 12:53 PM
firepop5's Avatar
This is my brother's car and he asked me for some help. He had his computer scanned at a parts store and they told him his O2 sensors were bad. Wanted to have as much info as possible before I start troubleshooting since I'm not familiar with the car. If I decide to swap out the sensors, is AC Delco worth the extra money or are Bosch replacements OK?
Old Jun 17, 2009 | 1:06 PM
ROTM Coordinator
What code(s) did it throw? They both may not be bad, it could even be something else.
Old Jun 20, 2009 | 12:36 PM
firepop5's Avatar
I got to see my brothers car today. The "Service vehicle soon" message is showing on dashboard. I scanned the OBD2 connector and got no codes. I would suspect if his O2 sensors were bad, the "check engine" light would come on instead of the service vehicle soon light anyway. I don't know why the shop he visited said he needed Os sensors. I saw their diagnostic report, and there are no codes listed, just a quote to change the O2 sensors.
According to his owners manual, if the service vehicle soon message appears, you must visit the dealer, or there is a problem with a trunk safety system. I'm pretty sure the car doesn't have this safety system on it.
After a little research I suspect the Body Control Module (BCM) is turning on the light. Does this BCM have a diagnostic connection and would an Auto Zone or similar place be able to diagnose or pull codes?
Old Jul 5, 2009 | 7:20 AM
no, autozone or any other parts store wont be able to read BCM codes. you'll most likely have to got to a dealer to get those codes as those codes can only br read with a tech II scanner. the only place i've seen with a tech II is a dealer. you dont have to take it to a chevy dealer, any GM dealer will have a tech II scanner.
Old Jul 6, 2009 | 12:43 PM
firepop5's Avatar
Ared the BCM codes also accessed from the OBD2 terminal under the dash?
