2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Po341 code
Old Jul 13, 2014 | 6:40 PM
Patton's Avatar
Default Po341 code
Replaced camshaft position sensor still have sane code it reads po341 any ideas??
Old Jul 13, 2014 | 7:10 PM
sledge.impy's Avatar
Did you reset the codes?
Old Jul 13, 2014 | 7:22 PM
Frank3's Avatar
In addition, I would check the connector to the camshaft position and see if it is bad, damaged or dirty.Check for bad/compromised wires and check for possible bad grounds.
Old Jul 13, 2014 | 7:24 PM
Patton's Avatar
Default Po341 codes
Yes, drove a few miles ck eng came back on . Had a block cat awhile back wonder if the timing chain is damaged
Old Jul 13, 2014 | 8:43 PM
Part 1 -How to Test the Cam Sensor (P0341) (GM 3.1L, 3.4L)
Old Jul 13, 2014 | 10:19 PM
firefighter831's Avatar
I would check the crankshaft sensor too... they usually both go at the same time. this just happened to me.
Donthaveone
Aug 27, 2013 9:45 PM
Vinna
Nov 12, 2012 8:51 AM
timT
Nov 21, 2011 10:29 PM
T'boo Ted
Oct 28, 2010 5:15 PM
tshunt01
Feb 19, 2007 12:26 AM
