Problems with A/C
My '06 Impala has an issue switching from circulating air to fresh air. The flap that switches back and forth makes a continuous clicking noise when trying to switch from circulating back to fresh/outside air. However from fresh air to circulating air there is no problem. The clicking usually last anywhere from 15-30 seconds with about 2 clicks per second then it will finally start pulling outside air. Could it be something is wrong with the flap, or is it a vacuum problem? I am not quite sure how this flap moves back and forth. I prefer to do all my own maintenance and would really love not to put the car in the shop for something small that they will charge a ton for.
I just started to hear the click in noise yesterday and it doesn't happen all the time so far. I have a 07 monte carlo Lt. did u ever found out what caused it and how to repair it? If so please let me know.
Thank You
Thank You
I actually called a chevy dealer yesterday and they informed me that it is a actuator valve. There are two in the impalas and monte carlos. He said one of them is a pain in the butt to get at and the other isn't so bad. We saw t parts on the internet yesterday pricing at around 30 dollars. I guess if you take it to a garage u r just going to be paying for the labor. If your car is under warranty they should just fix it. find out!
ac, air, car, changing, chevrolet, chevrolets, circulate, circulating, clicking, fromcirculating, makes, noise, problem, sound, tapping
