2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Old Jul 29, 2015, 1:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Reduced Power to Engine
Old Mar 30, 2012 | 11:01 PM
larkscards's Avatar
New User
Awaiting E-mail Confirmation
Default Reduced Power to Engine
06 Chevy Impala has check engine light on message on dash reduced power to engine, not sure what the problem is cleaned throttle bottle, not sure what to do next.
Old Mar 31, 2012 | 6:50 AM
EinST's Avatar
Welcome to the forum. The CEL is on with the "ENGINE POWER IS REDUCED" warning in the DIC. So, there should be one or more powertrain trouble codes (OBD-II, if you want to be exact) and freeze frames stored in a module. You can't go blindly about it like the old days. Consider taking it in for service.
Old Apr 1, 2012 | 1:56 PM
cleveland63b's Avatar
you'll atleast need the codes before you have a direction to go for anything
Old Apr 2, 2012 | 2:19 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> larkscards,
The Engine Power Is Reduced message will display when the vehicle’s engine power is reduced. Reduced engine power can affect the vehicle’s ability to accelerate. If this message is on, but there is no reduction in performance, proceed to your destination. The performance may be reduced the next time the vehicle is driven. The vehicle may be driven at a reduced speed while this message is on,
but acceleration and speed may be reduced. Anytime this message stays on, the vehicle should be taken to your GM dealer for service as soon as possible.
If you have additional questions, please feel free to contact me.
Louis
GM Customer Service
Old Feb 1, 2015 | 2:09 AM
bigjoe1987's Avatar
Default need help
my check engine light an my an engine power is reduced light is on what is the problem
Old Feb 1, 2015 | 2:10 AM
bigjoe1987's Avatar
[QUOTE=Chevrolet Customer Service;211559]<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> larkscards,
Louis
GM Customer Service[/QUO
I have a mechanic to come look at it he said it might be the fuel pump
Old Feb 1, 2015 | 11:20 AM
sledge.impy's Avatar
Whatever the code says is a good starting point.
If you don't know what it is, there's no way for us to know.
Old Feb 4, 2015 | 10:40 PM
Jaybird1185's Avatar
New User
Like everyone else said, we need a code to help you with your problem, most autoparts stores will run an OBDII check for free to give you a code and good idea of what your problem is. If you are also having a loss of power then it would be a code that would cause the ECU to cut power in order to prevent damage to the engine. This could be a misfire for instance or perhaps a knock was sensed therefore cutting the ignition timing to prevent damage. Even a clogged fuel filter could be causing such issues if it is sensing a drop in fuel pressure then it would have to cut back intensely to prevent a lean condition and burning a piston etc.
cdelta1975
Dec 4, 2019 12:56 AM
vivero
Jun 24, 2007 12:23 PM
vivero
Jun 23, 2007 2:38 PM
