2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
RPMs Too High?
Old Jan 20, 2009 | 4:57 PM
GermanyD2009's Avatar
Exclamation RPMs Too High?
Hello Chevy Forum.
I am having a problem with my 2007 Chevy Impala Automatic LT. And I hope someone can help me out with finding the answer. I purchased the car preowned with 14,000 on it. About 28,000 I noticed the RPM's are sitting up higher when starting the car and even while idling. I took my car in to get the 30,000 mile service done and told the tech about the high RPM's and they told me I would have to come back and talk to the tech person that takes care of transmissions. So that's another appointment I have to make.
So anyones input would be great.
Thank you
Old Jan 21, 2009 | 11:17 AM
rbarrios's Avatar
sucks.
Does it do this only in Park/neutral? or also in Drive/idle
could be that the thermostat is not closing and the engine is remaining in cold engine mode (higher RPMS's)
What is your temp gauge sitting at?
Old Jan 21, 2009 | 10:24 PM
EvansBlue's Avatar
Thats what I'm thinking too. It should tach around 1100 when the engine temp is below 190-205 F.
Old Jan 22, 2009 | 5:37 PM
Originally Posted by rbarrios
sucks.
It does do it in idle/park. The car warm up normally and doesn't run hot. The temp gauge hasn't changed. I quite positve it isn't the thermostat because I had that problem on my previous car.
Old Jan 22, 2009 | 7:34 PM
EvansBlue's Avatar
If it does it when its warmed up, then there is a problem. If it does it before it warms up, its normal.
Old Jan 22, 2009 | 10:41 PM
MDTAHOE's Avatar
Professional Mechanic
For up to the first 30 second of start up especially when cold the PCM will be in open loop. While in open loop the idle will be higher. If after this period the idle is up then something is definatly wrong. If not then it is normal. If it is still up it absolutly not the transmisson. There are many possible causes some of which are a vac leak, bad IAC (idle air control) bad TPS (throttle position sensor).
Old Jan 23, 2009 | 9:24 PM
Gwampa's Avatar
How about a build-up of "carbon-sticky" on the IAC pintle? But still low mileage for somthing like that.
Old Jan 24, 2009 | 10:19 AM
thanks guys. I'll mention all this info to the mechanic when I get the chance
Kohen Marzolf
Feb 12, 2013 2:07 PM
BillFos780
Nov 1, 2012 8:27 AM
DavidS
Apr 9, 2010 8:08 AM
ghost60
Feb 9, 2009 1:27 PM
benduran9
Jul 27, 2008 8:37 AM
