2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Turn key and nothing happens.
Old Oct 5, 2012 | 2:23 PM
johnfberglund@comcast.net's Avatar
Default Turn key and nothing happens.
I have a 2003 Impala.When I turn the key,dashboard lights and everything comes on but the engine doesn't turn. It may happen once a day or once a week or even several weeks. Battery checks good.
I am open to any suggestions.
Thanks for your help.
Please Help!
John B.
Old Oct 5, 2012 | 11:16 PM
tymr287's Avatar
Before condeming any parts make sure your battery cables are tight & free of corrosion @ the starter & ground.
Old Oct 6, 2012 | 7:22 PM
tomyear1's Avatar
Im having the same problem in my 2011. All the lights on the dash are lite and when i turn the key to start everything goes dead, no fuel pump, I can just hear some relays under the dash. This didnt happen over a period of time or give me any warning lights. I started the car and drove it in the morning started it up drove home went to use later that day and no start checked the battery and it read 9v. Replaced battery and still no start. Checked the started and its good, when key is turned to start no voltage to the solenoid wire. I'll tell you if I find out whats wrong.
Old Oct 9, 2012 | 10:33 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> tomyear1,
Is the vehicle cranking at all? This issue may be battery related (e.g. connection issue). This is just a suggestion, not a diagnosis. I encourage you to consult with a certified technician for an official diagnosis. They will be able to offer additional information after inspecting the vehicle.
Please keep us posted. If you have additional questions, please feel free to PM me.
Louis
GM Customer Service
Old Oct 9, 2012 | 1:32 PM
bekurt's Avatar
It may be your starter.
Old Oct 11, 2012 | 11:26 AM
tomyear1's Avatar
No it wasent cranking, I had it towed to the chevy dealer as it still under warranty. The ECM was hit with a voltage spike, maybe lightning here in Florida. But the dealer was great and replaced it without charge. Now the car starts fine and seems to have more power.
Old Oct 24, 2012 | 12:30 PM
Auto 360's Avatar
It's probably an issue with your battery. When you try to start it, there's no noise at all?
blaisa
Dec 23, 2015 12:06 AM
wilky
Nov 25, 2013 3:08 PM
G T Igofast
Sep 3, 2013 3:46 PM
bowtie58
Feb 10, 2013 9:35 PM
capucine
Uplander
Jun 6, 2010 11:19 PM
