Were can i run a cable through the fire wall
Hi there i want to run a power cable from the battery to the back of the car for an amp. Ive looked and cant find a part in the fire wall where other wires go in to the cab. i dont want to make a new hole. Does any one know where theres an opening? thanks message back
hopefully there aren't any open holes, then you'd be getting moisture and who knows what else inside your cab.
Normally when I run wires through the firewall I just follow the harness as you did and just poke a small hole in the grommet and force the wire through, then put a sealant or silicon over it on both sides.
stepsidechevy
October 22nd, 2010 3:20 PM
melonman12
January 19th, 2008 3:46 PM
