2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Were can i run a cable through the fire wall
Old Mar 14, 2012 | 2:42 PM
maddog19907's Avatar
Default Were can i run a cable through the fire wall
Hi there i want to run a power cable from the battery to the back of the car for an amp. Ive looked and cant find a part in the fire wall where other wires go in to the cab. i dont want to make a new hole. Does any one know where theres an opening? thanks message back
Old Mar 15, 2012 | 9:02 PM
cleveland63b's Avatar
hopefully there aren't any open holes, then you'd be getting moisture and who knows what else inside your cab.
Normally when I run wires through the firewall I just follow the harness as you did and just poke a small hole in the grommet and force the wire through, then put a sealant or silicon over it on both sides.
Old Mar 16, 2012 | 11:11 AM
Thanks for the reply it's hard to follow the harness cause the moter is so far back do you know what side there is an opening on
Old Mar 16, 2012 | 10:09 PM
theres usually a couple on the drivers side
stepsidechevy
Oct 22, 2010 3:20 PM
melonman12
Jan 19, 2008 3:46 PM
bgard
Nova & Chevy II
Dec 4, 2007 9:12 PM
ralphtrent
Jan 5, 2007 12:17 PM
