2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
where is the crankshaft postion sensor on a 2006 impala LT 3.5?
Old Aug 23, 2018 | 9:41 AM
sbreade's Avatar
Default where is the crankshaft postion sensor on a 2006 impala LT 3.5?
Old Aug 23, 2018 | 10:00 AM
oilcanhenry's Avatar
BTW, you may have to reprogram it. Not sure on that, but if it doesn't operate correctly, that will be the issue. Good luck!
Old Aug 23, 2018 | 2:42 PM
sbreade's Avatar
Thanks for your reply. The crankshaft part that i see online only has one 10mm bolt, why does this have 2 bolts? is a 2006 the same as a 2004? I cant find anything or any video that shows a 2006 impala crankshaft replacement or location.
Old Aug 23, 2018 | 4:33 PM
Looks like the third bolt holds the wire loom bracket. You have the 3.5 L. The other is for the 3.4 L it replaced, so yes, there was a change between the years.
Old Aug 24, 2018 | 9:35 AM
sbreade's Avatar
Would the wire going into the crankshaft sensor have heat deflecting tape on it? and is the easiest way to take this our from underneath or the wheel well?
Old Aug 24, 2018 | 7:57 PM
It may or may not have heat deflecting tape on it. If its near a place that gets real hot like exhaust or catalytic converter, then you can wrap it with protective tape.
Me, I dont like removing the wheels unless it's a brake job, so as its near the bottom of the motor, I'd use ramps or jack it up on stands and use a creeper to repair it..
