K5 Blazer 1969-1994
Platform: Truck, GMT 400
1993 Blazer with 5.7 automatic, having a crank no start
Old May 9, 2021 | 1:25 PM
BurnemGarage's Avatar
Default 1993 Blazer with 5.7 automatic, having a crank no start
(I know nothing about Chevy and I’m wanting to learn) Alright I’m in need of help, I was given a 93 Blazer with a 5.7 automatic to drive and One day after it got parked( only for a couple hours) it just cranks with no start(Yes it has fuel in tank). To cut it short I smell no fuel and see no fuel coming out of the carb when cranking. My grandmothers says she had just gotten a new fuel pump(she had the whole assembly replaced) put in a 11 months ago I’m not sure what could be wrong. If it is the fuel pump does someone have a guide or are there other things to check? I did some forum ready and someone mentioned the pump goes off oil pressure? The oil pressure when turned to the on position is 0, when cranking its 0 https://chevroletforum.com/forum/k5-blazer-22/92-k5-starting-problem-8936/
what are ways for me to check for issues before I attempt to dig out the pump.
Old May 9, 2021 | 2:18 PM
Rednucleus's Avatar
I have a 93 Suburban, same motor. I assume you have throttle body injection, not a carburetor. Easy things to try:
1. Turn key to on (not all the way to start) you should hear the fuel pump run/prime for several seconds. That will show you pump is getting power.
2. Remove air cleaner cover and pour small amount of gasoline down the throat (1/8-1/4 cup plenty). Now try to start. If it fires you have spark, just no fuel from the injectors.
Old May 9, 2021 | 2:22 PM
Yes it has the tdi. I havnt tried listening for the pump but I did try pouring fuel down it and it fired and proceeded to die when I stopped giving it fuel
Old May 9, 2021 | 3:48 PM
kevinkpk's Avatar
Can you hear the fuel pump come on with key switch on, no crank?
Old May 9, 2021 | 10:43 PM
Rednucleus's Avatar
Since it fires with fuel, if you hear the fuel pump run at key on and you want to try a relatively easy fix, try changing the ICM inside the distributor. I am on my 3rd one. Make sure to use the heat paste!
Old May 10, 2021 | 12:00 AM
I do not hear any noise from the fuel pump region.
Dirty bigs
Blazer
Jan 11, 2020 6:19 PM
Df0927
Dec 23, 2013 4:18 PM
JEFFRO BO DEAN
K5 Blazer
Feb 16, 2013 4:19 AM
The Untouchables
Sep 22, 2009 7:54 PM
92K5
K5 Blazer
Aug 22, 2007 11:14 AM
