K5 Blazer 1969-1994
Platform: Truck, GMT 400
Got me some tranny problems any advice
Old Jul 28, 2013 | 4:58 PM
Blazingjake's Avatar
Default Got me some tranny problems any advice
Just put me a salvaged 4L80E automatic tranny in my 1994 6.5 blazer and when i put it in gear it does nothing. i stomp on the gas , almost redlining and it will budge forward or backward what ever gear im in. I don't know what this is? Maybe not enough tranny fluid in the torque converter maybe? i know the tranny is full of fluid. someone told me to let it idle in neutral and that will pump the converter full and i let it idle for and hour in neutral and that dnt help. any advice will be appreciated thanks!
Old Jul 28, 2013 | 5:51 PM
either you got a bad trans or something went wrong during installation. Either way, the trans "gotsta" come out.
how reputable is your trans supplier? He will ask, how competent are your installation skills.
Old Jul 29, 2013 | 12:46 AM
got darn it! i bought the tranny of ebay for about 800 bucks. installation went perfect took our time putting it in making sure the converter spun perfect and all. but i was too much in a hurry to see if it had enough fluid in it. ima take it off tomorrow and check it im hoping thats my problem. im only 18 , i know a little bit bout mechanics for my age. its my dads truck but he dont have enough money to fix it so im draining mine it to make him happy . id rather dump my hard earned money in then see the dream goto the scrap yard.. im hoping it aint shot wish me luck!
Old Jun 24, 2014 | 12:48 AM
k5britney's Avatar
Default tranny/transfer case issues
My turbo 350 and NP 205 are sharing tranny fluid...is this normal?? I pulled the drain plug off the transfer case and tranny fluid came pouring out! I pulled the transfer case out, which was a pain in the *** when you do it laying on your back........and replaced the seal and it still doing it! Visit supposed to??
Old Jun 24, 2014 | 12:51 AM
k5britney's Avatar
When you put the tranny in did you align the two notches on the front pump? If not you probably broke the front pump and ...yes....the tranny is junk and must be replaced
Ryan Brickel
May 25, 2012 4:06 PM
wallstreetamigo
Apr 3, 2010 7:13 AM
Zayde
Jun 26, 2008 7:36 PM
sandlercd_22
Jan 5, 2008 9:33 PM
antmesa
Aug 28, 2006 3:35 PM
