K5 Blazer 1969-1994
Platform: Truck, GMT 400
K5 Blazer Stalling
Old May 14, 2009 | 9:58 PM
pcharles's Avatar
Default K5 Blazer Stalling
I just bought a 85 K5 and had new belts put on, and fluids changed. Drove it home and on the way it stalled out on me. It would start back up and I would go to put my foot on the gas and it would die. It keep doing that so I called the place that did my service. They towed it back to the shop. changed the fuel pump, rebuilt the Carbuerator, new starter, Reset the timing. I picked it up and the same thing happened. can you help please?
Old May 14, 2009 | 10:06 PM
suzuki-guy's Avatar
Welcome to the forum! Stop by the New member welcome area if you would like!
Fuel delivery problem. Check your pump, and filter!
Old May 14, 2009 | 10:10 PM
pcharles's Avatar
Thanks for the welcome!
Both the pump and the filter have been replaced since the first stall. It didn't seem to fix the problem.
Old May 14, 2009 | 10:38 PM
suzuki-guy's Avatar
Hmm did you verify the timing yourself?
Old May 14, 2009 | 11:04 PM
pcharles's Avatar
No, the shop did and they checked all the spark plugs. It's sparking fine.
Old May 14, 2009 | 11:07 PM
suzuki-guy's Avatar
Hmm.. Im stumped here... Did you check fuel pressure? Kind of sounds like idle/air mixture screws could be off to.. The way i do those is screw them all the way in then two and a half turns out. Does it pop when it quits? Like out of the carb.?
Old May 15, 2009 | 7:09 AM
pcharles's Avatar
Yes. It does pop when it quits. I have talked to different people and some say there could be a leak from the manifold. The last thing the shop told me is that they sprayed on the right hand side of the motor and the idle fluctuated, but in a good way. Could it be that?
Old May 15, 2009 | 1:09 PM
suzuki-guy's Avatar
Yes it could be a vaccum leak! Check your intake, also check all your vaccuum lines!
Old May 16, 2009 | 9:47 PM
pcharles's Avatar
Ok another issue. Back power window motor goes down, but hit the switch to go up and nothing. So window is now down. Can anyone help.
Old May 18, 2009 | 6:38 PM
pcharles's Avatar
Ok, After a new fuel pump, starter, Rebuilt Carb, Fuel filter, timing adjusted, and now new manifold gaskets, it ran great last night, today to work back home again it sat for a hour went to drive around the block and it tried to pop and shut off again. I put in neutral revved it up again and got it home. Anyone please help.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
