K5 Blazer 1969-1994
Platform: Truck, GMT 400
slow high end?
Old Aug 7, 2010 | 12:37 AM
King5's Avatar
Default slow high end?
Just put in a rebuilt 350 in my blazer, and when I get on the highway and speed up the acceleration slows down considerably once i hit 45mph. What could it be? I'm thinking timing is off, could that be it?
Old Aug 7, 2010 | 9:08 AM
maxxman04's Avatar
timing is def a good place to start.
Old Aug 19, 2010 | 9:48 PM
Nathan C's Avatar
Default me too
I am having a very similar problem with a K5 I just put a 305 in. It's impossible to see the timing marks. Dang thing runs great until about 35-45, then acts like a govenor is cutting power.
Old Aug 20, 2010 | 1:03 AM
2wd-K5's Avatar
is the exhaust emission valve on the pass side open? is it at the exhaust manifold collector
Old Aug 20, 2010 | 2:26 AM
Nathan C's Avatar
I checked the valve in the exaust manifold before installing the engine to make sure it was normally open, because I removed all of the vacuum stuff. It seemed like a pretty strong spring holds that open. So, I think it is open.
Old Aug 21, 2010 | 5:04 PM
2wd-K5's Avatar
is your choke sticking?
Old Nov 13, 2010 | 12:03 AM
CS057's Avatar
Default Same problem
I have a smooth running 305 with edelbrock carb and intake. I have great acceleration and power at low speeds, but at 4th gear power just drops completely and I can barely make it to 65.
in2pro
Dec 25, 2020 11:34 PM
hardbalance
Apr 30, 2015 10:57 PM
otis_xing
Apr 13, 2013 2:31 PM
Jing
Apr 15, 2011 4:03 PM
birdie
15
Jul 8, 2010 11:09 AM
