K5 Blazer 1969-1994
Platform: Truck, GMT 400
Steering knuckle repair / ignition problem
Old Dec 21, 2011 | 2:23 PM
CritterGitter91K5's Avatar
Default Steering knuckle repair / ignition problem
Hello all,
I just had to pull the steering wheel, lock plate assembly and the rest off to get to the steering knuckle so that I could get to the 4 bolts that needed to be tightened so that the steering could be tightened. After doing everything I needed to I started to reassemble everything the way that it came off. When I put the ignition tumbler back in I noticed that when I turn the key I can't get anything to work. The ignition just turns and nothing happens. When I put the top part of the column back on my radio turned on and now I can't get it to turn off. What in the world did I do wrong? Any suggestions?
Thanks in advance.
Old Jan 14, 2012 | 4:54 AM
2wd-K5's Avatar
my sugestion would be to get a junkyard column (thats what i would do) every time i mess with columns it doesnt go good
whitestingray81
Avalanche
May 1, 2014 1:27 AM
hsboatwright
Mar 8, 2014 6:43 PM
conkatonk
Mar 5, 2012 7:52 PM
conkatonk
Mar 4, 2012 12:18 AM
jonmad99
Jul 2, 2008 2:24 PM
