Chevrolet Malibu
1998 malibu
Old Jun 19, 2006 | 5:07 PM
MACHAY's Avatar
Default 1998 malibu
i have a 98 malibu and i put a new optima battery in it. after i did this i went to start it and the gas gauge spun all the way around so it is now upside down. does anyone know if this is a common problem? and a way to fix it?
Old Aug 6, 2006 | 2:30 PM
polishpat's Avatar
Default RE: 1998 malibu
Its a typical problem when u install new batteries in the malibu......the needle gets a bigger boost of energy than its supposed to...causing it to go around too far. You will have to take the instrument cluster out to fix it. basically just spinm it back around with your finger(MAKE SURE NOT TO REMOVE THE NEEDLE) they are very delicate and once the needle pops off...you wont be able to put it back in exactly how it was
Old Aug 7, 2006 | 2:49 AM
NCHEVYHEVN's Avatar
Well since you decided to pull up an old thread I'll go ahead and reply anyway.
Basically pulling the instrument panel is the hard/slow way to fix the problem. What I do is just take a paperclip and stick it through the hole where the odometer reset stick pokes through the clear plastic. From their I can pull the needle back around to where it normally is.
04cad
Mar 26, 2008 8:53 PM
celtic820
Nov 9, 2007 10:55 PM
bushygoose
Sep 5, 2007 11:11 AM
Tomahawk06
Dec 6, 2006 2:23 PM
CountryGirl
Jun 25, 2006 1:21 AM
